Superfluous Equivent triggers
Is it me, or is it Equiwatt
To participate in Equivents I use the the webhooks to trigger a virtual switch.
Home Automation script then shuts down (mainly lighting) via smart devices. When the Equivent ends, similarly, a script then runs to restart devices.
I call Equivent start a PowerDown, and Equivent ends a PowerUp.
The webhooks hit my URLs usually a seconds or so after the start/
end of the Equivent.
I noted recently a few Equivent triggers at times like:
  1. EquiwattPowerUp is triggered at 2025-11-21 18:00:08
  2. EquiwattPowerUp is triggered at 2025-11-21 18:30:07
  3. EquiwattPowerUp is triggered at 2025-11-21 19:00:08
  4. EquiwattPowerDown is triggered at 2025-11-21 19:02:20
  5. EquiwattPowerUp is triggered at 2025-11-21 19:30:07
  6. EquiwattPowerUp is triggered at 2025-11-21 20:00:09
  7. EquiwattPowerUp is triggered at 2025-11-21 20:00:49
On 21 November 2025 there was indeed an Equivent from 19:00 to 20:00.
Now the triggers 1 to 3, are ignored. My virtual switch remains off.
Trigger 4 turns my switch on that’s runs my power down script.
Trigger 5 was premature and ran my power up script too early.
Triggers 6 and 7 would have run my power up script.
So my question is why have there been superfluous Equivent end triggers, and more importantly why was there a Equivent end triggers some 30 minutes early?
Hi @Jeremy_Goff, thank you for flagging this..this might be a weird bug. The team are now checking on this and we will get back to you once it’s solved.
I received another this evening:
EquiwattPowerUp is triggered at 2025-11-25 19:00:08
But it was ignored :grin:
Thanks @Jeremy_Goff. All of the detail has been very useful in figuring out what the issue is. We should have this solved in the next couple of days.
Thank you for your diligence. I had triggers at 19:00 and 19:30 last night too, both Equiwatt ends so ignored.
Hi @Jeremy_Goff, the fix for this has been pushed now. Please let us know if it happens again. Thank you once again for flagging it!
